[GRASS-dev] Re: [GRASS-user] lots of "The application failed to initialize properly" in 6.4.0 on Windows
Sat Sep 11 15:38:41 EDT 2010
Maciej Sieczka wrote:
> Lots of commands (e.g. g.proj, g.region, g.remove)
That list looks suspiciously like "programs which use GDAL".
You might want to check whether there are other versions of GDAL on
your system, particularly if they are in %PATH%.
