[GRASS-dev] [GRASS GIS] #1153: Problem with graduated point symbols
GRASS GIS trac at osgeo.org
Sun Sep 12 13:34:47 EDT 2010
 Reporter:  abevan           |       Owner:  grass-dev@…
     Type:  defect           |      Status:  new
 Priority:  normal           |   Milestone:  7.0.0
Component:  Display          |     Version:  svn-trunk
 Keywords:  d.vect.thematic  |    Platform:  MacOSX
      Cpu:  OSX/Intel        |
 GRASS 7.0.svn (spearfish):~ > g.copy
 vect=archsites at PERMANENT,myarchsites[[BR]]
 Copy vector <archsites at PERMANENT> to current mapset as <myarchsites>[[BR]]
 GRASS 7.0.svn (spearfish):~ > v.build map=myarchsites[[BR]]
 Building topology for vector map <myarchsites at user1>...[[BR]]
 Registering primitives...
 25 primitives registered
 25 vertices registered
 Building areas...
  100%
 0 areas built
 0 isles built
 Attaching islands...
 Attaching centroids...
  100%
 Number of nodes: 25
 Number of primitives: 25
 Number of points: 25
 Number of lines: 0
 Number of boundaries: 0
 Number of centroids: 0
 Number of areas: 0
 Number of isles: 0
 [[BR]]
 GRASS 7.0.svn (spearfish):~ > d.vect.thematic map=myarchsites type=point
 column=cat themetype=graduated_points themecalc=interval nint=5
 Thematic map legend for column cat of map myarchsites
 Value range: 1.0 - 25.0
 Mapped by 5 intervals of 4.8
 Size/width      Value
 [[BR]]
 [[BR]]
   File
 "/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/scripts/d.vect.thematic",
 line 1129, in <module>
     main()
   File
 line 944, in main
     if themetype == graduated_lines:
 NameError: global name 'graduated_lines' is not defined[[BR]]
Ticket URL: <http://trac.osgeo.org/grass/ticket/1153>
