[GRASS-dev] Re: [GRASS GIS] #1159: v.in.ascii points import fails in WinGRASS-6.4.0-1
GRASS GIS trac at osgeo.org
Tue Sep 21 16:27:37 EDT 2010
 Reporter:  lponti      |       Owner:  grass-dev@…
     Type:  defect      |      Status:  new
 Priority:  blocker     |   Milestone:  6.4.1
Component:  Vector      |     Version:  6.4.0
 Keywords:  v.in.ascii  |    Platform:  MSWindows 7
      Cpu:  x86-32      |
Comment(by lponti):
 Replying to [comment:14 hamish]:
 > patch to replace G_fatal_error() with G_debug() message applied to
 6.5svn with r43550. please test..
 > is this failing in grass7 as well?
 > Hamish
 Applied Glynn's patch
 http://osgeo-org.1803224.n2.nabble.com/v-in-ascii-fails-with-long-text-
 file-in-WinGRASS-6-4-0-1-tp5530779p5553622.html
 to changeset 4359 releasebranch_6_4, compiled following instructions at
 <http://trac.osgeo.org/grass/wiki/CompileOnWindows>, and it works for the
 your simple test (see
 <http://trac.osgeo.org/grass/ticket/1159#comment:13>):
     GRASS 6.4> echo "10|10|abcd" | v.in.ascii out=test
     Scanning input for column types...
     Maximum input row length: 11
     Maximum number of columns: 3
     Minimum number of columns: 3
     Column: 1 type: double
     Column: 2 type: double
     Column: 3 type: string length: 4
     Importando punti ...
      100%
     Populating table...
     Building topology for vector map <test>...
     Registering primitives...
     1 primitives registered
     1 vertices registered
     Building areas...
      100%
     0 areas built
     0 isles built
     Attaching islands...
     Attaching centroids...
      100%
     Number of nodes: 1
     Number of primitives: 1
     Number of points: 1
     Number of lines: 0
     Number of boundaries: 0
     Number of centroids: 0
     Number of areas: 0
     Number of isles: 0
     v.in.ascii completo.
 The point can be displayed, and the dbf table seems ok. Also works using a
 longer sample text file I previously linked
     GRASS 6.4> v.in.ascii --overwrite input=Bloomday_Olive_11set10_Avg
 output=test_US_import fs=tab
     ATTENZIONE: Vector map <test_US_import> already exists and will be
                 overwritten
     Maximum input row length: 31
     Column: 3 type: double
      100%
     Populating table...
     Building topology for vector map <test_US_import>...
     1157 primitives registered
     1157 vertices registered
     Building areas...
      100%
     0 areas built
     0 isles built
      100%
     Number of nodes: 1154
     Number of primitives: 1157
     Number of points: 1157
     Number of lines: 0
     Number of areas: 0
     Number of isles: 0
 Related ticket 1158 <http://trac.osgeo.org/grass/ticket/1158> seems to
 persist:
 input=C:/cygwin/home/andy/models_temp/Bloomd
     ay_Olive_11set10_Avg output=test_US_import fs=tab
                 overwritten
     ATTENZIONE: Unable to delete file
 'C:\cygwin\home\andy/latlong/luigi/vector/test_US_import/hist'
     ERRORE: Unable to delete vector map <test_US_import>
 Still not entirely clear to me which variable I am supposed to set in
 order to get full English messages.
 Thanks and regards,
 Luigi
Ticket URL: <http://trac.osgeo.org/grass/ticket/1159#comment:15>
