[GRASS-dev] Re: [GRASS GIS] #699: v.buffer2 segfault: in Vect_get_isle_points()
GRASS GIS trac at osgeo.org
Mon Apr 4 06:03:02 EDT 2011
  Reporter:  neteler  |       Owner:  grass-dev@…
      Type:  defect   |      Status:  closed
  Priority:  normal   |   Milestone:  7.0.0
 Component:  Vector   |     Version:  6.4.0 RCs
Resolution:  fixed    |    Keywords:  v.buffer
  Platform:  All      |         Cpu:  All
Comment(by mmetz):
 Replying to [comment:26 mlennert]:
 > However, testing with the other example (see Mon, Oct 9 2006 08:02:33)
 from the old RT report gives the following, seems to reveal some remaining
 issues.
 > First of all, I cannot reproduce the procedure exactly, as the v.buffer
 call with bufcolumn=lane_cout gives me
 > GRASS 7.0.svn (nc_spm_06):~ > v.buffer vbuf_fill_bug bufcol=lane_count
 out=vbuf_fill_bug_lanes scale=150
 > ATTENTION : The bufcol option may contain bugs during the cleaning step.
 If
 >             you encounter problems, use the debug option or clean
 manually
 >             with v.clean tool=break; v.category step=0; v.extract -d
 >             type=area
 > ERREUR :The bufcol option requires a valid layer.
 Note that v.buffer in grass 7 is the same like v.buffer2 in grass 6.x. The
 original v.buffer has been removed from grass 7 some time ago. Testing the
 buffer/parallel modules should take place in grass 6.5 only.
 It seems v.buffer2 has issues with the test cases described in the old RT
 bug 2765 whereas v.buffer does not...
Ticket URL: <https://trac.osgeo.org/grass/ticket/699#comment:27>
