[GRASS-dev] Compiling and running a module in winGRASS- not running in Win7 but yes in XP
Jenny Turner jennyturner1980 at gmail.com
Wed Apr 6 06:26:41 EDT 2011
I have built a GRASS module to perform image segmentation. But, to have this
running fine I neeeded
1- g++ -fpic -c segmentimage.cpp
2- g++ -shared -o libsegmentimage.dll segmentimage.o
3- Placed .dll file in lib folder of dist folder in OSGEO4w
4- added -lsegmentimage in makefile
5- compiled successfully with make -C i.segment
make: Entering directory `/c/osgeo4w/usr/src/i.segment'
gcc -L/c/osgeo4w/usr/src/grass-6.4.svn/dist.i686-pc-ming
-Wl,--export-dynamic,--enable-runtime-pseudo-reloc  -L/c/OSGeo4W/apps/gd
       al-16/lib -L/c/OSGeo4W/lib     -o
OBJ.i686-pc-mingw32/hist.o OBJ.i686-pc-mingw32/main.o
OBJ.i686-pc-mingw32/open.o /C/OSGeo4W/usr/src/grass-6.4.
 svn/lib/gis/OBJ.i686-pc-mingw32/fmode.o -lgrass_I -lgras   s_gis
-lgrass_datetime -lxdr -liberty -lws2_32    -lz   -lintl   -lgrass_gis -lg
 -lgrass_gmath -lgrass_gis
-lws2_32    -lz   -lintl   -lsegmentimage  -lxd
                                                           r -liberty
-lws2_32    -lz
make htmlcmd
make[1]: Entering directory `/c/osgeo4w/usr/src/i.segment'
make /c/osgeo4w/usr/src/grass-6.4.svn/dist.i686-pc-mingw
make[2]: Entering directory `/c/osgeo4w/usr/src/i.segment'
if [ "/c/osgeo4w/usr/src/grass-6.4.svn/dist.i686-pc-ming
 w32/bin/i.segment.exe" != "" ] ; then
GISBASE=c:/osgeo4w/usr/src/grass-6.4.svn/dist.i686-pc-mingw32 PATH="/c
 $PATH" PATH="/c/osgeo4w/usr/src/grass-6.4.svn/dist.i686-
           gram Files/Common Files/Microsoft Shared/Windows Live:/c/Program
Files (x86)/Com
Files (x8
Technologies/ATI.ACE/Core-Static:/c/MATLAB7/bin/win32:/c/Program Files (x
         86)/Windows Live/Shared:.:/bin:/bin" LC_ALL=C
                              < /dev/null | grep -v '</body>\|</html>' >
i.segment.tmp.html ; true ; fi
/C/OSGeo4W/usr/src/grass-6.4.svn/tools/mkhtml.sh i.segme
        nt ;
mkdir -p /c/osgeo4w/usr/src/grass-6.4.svn/dist.i686
 -pc-mingw32/docs/html ; /bin/install -c  -m 644 i.segment.tmp.html
           ment.html ; for file in  *.png *.jpg ; do head -n 1 $file | grep
'^#!' > /dev/nu
                           ll ; if [ $? -ne 0 ] ; then /bin/install -c  -m
644 $file /c/osgeo4w/usr/src/gra
 ss-6.4.svn/dist.i686-pc-mingw32/docs/html ; fi done 2> /
 dev/null ; true
make[2]: Leaving directory `/c/osgeo4w/usr/src/i.segment'
make[1]: Leaving directory `/c/osgeo4w/usr/src/i.segment'
make mancmd
make[1]: Nothing to be done for `mancmd'.
make: Leaving directory `/c/osgeo4w/usr/src/i.segment'
This was built in Msys in a Win7 machine
6- Then I placed exe and dll in OSGEO4w/apps/grass/grass6.4.1svn/bin
7- I runned in WinGRASS in WinXP and it runned just fine
8- I runned in WinGRASS in Win7 and I got a pop window checking error and
the following was printed in GRASS Command window:
This application has requested the Runtime to terminate it
in an unusual way.
Please contact the application's support team for more
HAs anyone an idea of what might be happening?
[GRASS]- Running a module in Win7 and XP
Jenny Turner to hellik
show details 1:24 AM (9 hours ago)
I have built a module, with a shared .dll file, and I've been able to run it
in WinXP but not in Win7. In Win/ i get:
in an unusual way.
Do you have any advice on what might be happening? The weirdest thing is
that I have compiled with OSGEO4W in Win7 not in WinXP.
If you want, or if you are able to help me, I can send you my code and my
Why am I sending you this email? because you are the most active wiNGRASS
user/dev. and maybe you are the one that can help me
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20110406/656c7924/attachment.html
