[GRASS-dev] Re: ctypes problem with Vect_open_old
Hamish hamish_b at yahoo.com
Wed Aug 3 08:46:34 EDT 2011
Martin wrote:
> Can someone with Debian unstable test it?
sorry, I am away from my dev machine right now, but fyi if
someone wants to go to the trouble it is not too hard to set
up a virtual machine instance to do it. instructions for qemu-
kvm follow:   (kvm requires newish cpu + linux kernel; mac and
ms windows users could use Sun's VirtualBox)
# '-m' is memory to use in MB
# '-boot d' tells it to boot from the virtual-CD drive first (the ISO)
ISO=debian-6.0.1a-amd64-netinst.iso
IMG=debian_sid_minimal_VM-amd64.img
## create and install to a disk image
#kvm-img create -f qcow2 $IMG 20G
#kvm -hda $IMG -cdrom $ISO -m 1024 -boot d
kvm -hda ~/iso/VMs/$IMG -m 1024 \
   -cpu phenom -smp 2 -redir 'tcp:2222::22' \
   -nographic -daemonize
# (first time probably skip the '-nographic -daemonize')
## modify /etc/apt/sources.list to point to sid
#apt-get update && apt-get upgrade
# at this point I usually copy + bzip2 the fresh image.
#ssh -p 2222 user at localhost
#scp -P 2222 file user at localhost:
hope it helps,
Hamish
