[GRASS-dev] Renaming G3d into Rast3d
Martin Landa landa.martin at gmail.com
Thu Aug 11 06:24:28 EDT 2011
2011/8/11 Soeren Gebbert <soerengebbert at googlemail.com>:
> i just noticed that massive renaming in the G3d library is going on.
> Nothing against to follow name convention, but it would be nice if
> this kind of changes are discussed in the list first, so i can prepare
> myself and my G3d dependent software for it.
> I only noticed the changes because my vtk-grass-bridge is not working
> anymore ... .
sorry for inconvenience, this step should have been done much more
earlier, but nobody did it. There are more important issues - fn
naming convention in this library completely breaks standard naming
convention from other GRASS core libraries. Moreover, some of the fns
should be replaced by similar functions for GIS library (see at least
alloc.c and error.c). I decided just to break the ice ;-) Anyway I
should have to announce it. Are you interested to rename and clean up
subroutines in this library towards standard naming convention and no
overlap with other (GIS and Raster) libraries?
Thanks, Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
