[GRASS-dev] Renaming G3d into Rast3d
Soeren Gebbert soerengebbert at googlemail.com
Thu Aug 11 11:19:06 EDT 2011
Hello Martin,
renaming the G3D -> Raster3d functions to follow the grass naming
convention is on my TODO list for years now ... . But i never took the
time to start, so thanks for making the first step. Unfortunately i
have currently no time to join you. :/
Best regards
Soeren
2011/8/11 Martin Landa <landa.martin at gmail.com>:
> Hi,
> 2011/8/11 Soeren Gebbert <soerengebbert at googlemail.com>:
>> i just noticed that massive renaming in the G3d library is going on.
>> Nothing against to follow name convention, but it would be nice if
>> this kind of changes are discussed in the list first, so i can prepare
>> myself and my G3d dependent software for it.
>> I only noticed the changes because my vtk-grass-bridge is not working
>> anymore ... .
> sorry for inconvenience, this step should have been done much more
> earlier, but nobody did it. There are more important issues - fn
> naming convention in this library completely breaks standard naming
> convention from other GRASS core libraries. Moreover, some of the fns
> should be replaced by similar functions for GIS library (see at least
> alloc.c and error.c). I decided just to break the ice ;-) Anyway I
> should have to announce it. Are you interested to rename and clean up
> subroutines in this library towards standard naming convention and no
> overlap with other (GIS and Raster) libraries?
> Thanks, Martin
> Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
