[GRASS-dev] R.terraflow on massive grids
Doug_Newcomb at fws.gov Doug_Newcomb at fws.gov
Fri Aug 12 09:49:31 EDT 2011
Hi Folks,
I have an fcell grid of elevations for the state of North Carolina (51000
rows 133000 columns 6783000000 cells) .  I tried to run r.terraflow in
GRASS7 ( 8/8/2011 svn snapshot) and ran into the dimension limits.  So I
patched them according to Glynn's email ,
http://www.osgeo.org/pipermail/grass-user/2004-February/024722.html  and
tried again ( Would it be better to change the  dimension variable to int
instead of  short int?) .
This time my Streams file builds to about 26 GB and then r.terraflow bombs
with :
MFD flow direction
D8CUT=999999986991104.000000
Memory size: 808.00M (847249408) bytes
Memory manager registering memory in MM_IGNORE_MEMORY_EXCEEDED mode.
r.terraflow: grass2str.h:145: AMI_STREAM<T>*
cell2stream(char*, elevation_type, long int*) [with T =
float, elevation_type = float]: Assertion `nrows * ncols ==
str->stream_len()' failed.
The memory size is interesting, because I'm giving it 8GB of RAM out of 16
GB in the command.  The temp directory has about 900GB of space, so it has
plenty of room .
The box is 64 bit Ubuntu 11.04
related to ?
http://trac.osgeo.org/grass/ticket/1006
I can run it again in verbose mode when I get home tonight.
Doug
Doug Newcomb
USFWS
Raleigh, NC
919-856-4520 ext. 14 doug_newcomb at fws.gov
The opinions I express are my own and are not representative of the
official policy of the U.S.Fish and Wildlife Service or Dept. of the
Interior.   Life is too short for undocumented, proprietary data formats.
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20110812/3f169a64/attachment.html
