[GRASS-dev] can't find : mapdisp_command.py
massimo di stefano massimodisasha at gmail.com
Fri Aug 12 16:08:40 EDT 2011
Hi Martin,
thanks for the hints,
i tried :
d.mon start=wx0
d.rast map=mymap
adding this command in a grass wxpython extension module,
allow me to start a new map-dislpay and visualize a raster map on it.
how can i interact whit this new generated canvas ?
i tried to use "d.where" but seems to me that it is is not connected to the
active/selected map-display.
thanks for any hints,
-- Massimo.
2011/8/12 Martin Landa <landa.martin at gmail.com>
> Hi,
> 2011/8/12 Massimo Di Stefano <massimodisasha at gmail.com>:
> > no module named mapdisp_command
> > actually i checked in the grass7.0 source svn (rev.: 47601 ) but i can't
> find it.
> > please have you any hints/suggestion/example-code to achieve my target ?
> this python module has been recently removed, see newly added GRASS
> module d.mon for wx-monitor usage.
> Martin
> Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20110812/8188f04a/attachment.html
