[GRASS-dev] can't find : mapdisp_command.py
Massimo Di Stefano massimodisasha at gmail.com
Fri Aug 12 16:58:59 EDT 2011
Il giorno 12/ago/2011, alle ore 22.24, Martin Landa ha scritto:
> Hi,
> 2011/8/12 massimo di stefano <massimodisasha at gmail.com>:
>> how can i interact whit this new generated canvas ?
> use wxGUI map display functionality...
so, after a sequence of
d.mon start=wx0
d.rast map=map
then is possible to use wx.GUI functionality (api?) to interact whi "wx0" ?
which class i need to import in the python module in order to capture the mouse on-click signal ?
in the wxgui code, where can i find the lines of code that refer to mouse mapcanvas picking ?
thanks for any usefull hints!
--Massimo.
>> i tried to use "d.where" but seems to me that it is is not connected to the
>> active/selected map-display.
> d.mon is a quite new creature in G7, `d.where` is not connected to the
> wx monitors.
> Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
