[GRASS-dev] Re: OS X Lion: wxpython 2.9
Michael Barton Michael.Barton at asu.edu
Mon Aug 15 13:18:01 EDT 2011
William,
Are the missing API's a problem for GRASS?
Can you get a GRASS/terminal/wxGUI terminal error message? The one from Apple is less helpful. But if that is the only one you have, can you send it? I wonder if it is a 64bit compilation issue?
Michael
______________________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
Tempe, AZ  85287-2402
USA
voice: 	480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax:          480-965-7671(SHESC), 480-727-0709 (CSDC)
www: 	http://csdc.asu.edu, http://shesc.asu.edu
		http://www.public.asu.edu/~cmbarton
On Aug 13, 2011, at 12:25 PM, William Kyngesburye wrote:
> This is now a real problem - wxpython 2.8.x series will not compile on OS X Lion.  Lion appears to have the remaining pure-Carbon bits removed (that wxpython 2.8 needs).  I think it's really only a problem for OpenGL - that's where I get compile errors in wxPython, the GUI seems to run with a wxPython compiled on earlier system versions (and I don't run into OpenGL because wxnviz is not enabled for GRASS 6.4).
> The 2.9 dev series has a cocoa option now, but 2.9 is in development.  Nice bonus: it's now finally 64bit.  But there are some issues yet to work out.  A couple APIs were deprecated in OSX 10.6 and removed in 10.7, and so far no definite solution is in the wxPython code.
> The only options then are (to be able to use wx 2.9 cocoa where OpenGL is usable)
> - to compile for the 10.6 SDK, thus the system Python 2.6
> - to compile for the 10.6 SDK with python.org (or other) Python 2.7 (if python 2.7 is wanted)
> There is a downloadable wxpython 2.9 cocoa from wxpython.org, that is built for 64bit python 2.7 on OSX 10.5+, but the GUI crashes on startup with this.  I can't tell if it's a GRASS problem, I can copy the crash report to list if anyone's interested (it's a long stack trace), or start a bug report, but I don't have time to poke around with it much.
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "Time is an illusion - lunchtime doubly so."
> - Ford Prefect
