[GRASS-dev] R.terraflow on massive grids
Tue Aug 16 03:03:15 EDT 2011
Hamish wrote:
> > The iostream library uses size_t. However, r.terraflow
> > itself had a bug (scale then cast instead of cast then scale),
> > which should be fixed by r47641.
> in the same class, but sort of unrelated- any thoughts on #1107?
>   https://trac.osgeo.org/grass/ticket/1107
I'm fairly certain that it's supposed to be float and atoi() is a
typo.
Fixed in r47664.
