[GRASS-dev] Re: [GRASS GIS] #1110: v.rast.stats locks up on wingrass
GRASS GIS trac at osgeo.org
Sun Aug 21 18:34:58 EDT 2011
 Reporter:  hamish                                       |       Owner:  grass-dev@…
     Type:  defect                                       |      Status:  new
 Priority:  critical                                     |   Milestone:  6.4.2
Component:  Vector                                       |     Version:  svn-releasebranch64
 Keywords:  wingrass, v.rast.stats, v.db.addcol, v.info  |    Platform:  MSWindows XP
      Cpu:  x86-32                                       |
Comment(by hamish):
 Replying to [comment:6 hellik]:
 > so it seems that the v.db.addcol-script can't be find by the
 > v.rast.stat-script when wingrass is started via grass64svn.bat,
 > but it's possible in wingrass started via msys-way.
 .. interesting.
 does v.in.lines work in the grass64svn.bat cases?
 C:\> copy con test.dat
 167.846717,-46.516653
 167.846663,-46.516645
 167.846656,-46.516644
 167.846649,-46.516644
 167.846642,-46.516643
 NaN,NaN
 167.846520,-46.516457
 167.846528,-46.516461
 167.846537,-46.516464
 167.846535,-46.516486
 167.846544,-46.516489
 167.846552,-46.516493
 ^Z
 v.in.lines in=test.dat out=two_lines fs=,
 thanks,
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1110#comment:7>
