[GRASS-dev] Create new branch from trunk for temporal GIS integration
Markus Neteler neteler at osgeo.org
Tue Aug 23 04:27:32 EDT 2011
On Tue, Aug 23, 2011 at 8:57 AM, Martin Landa <landa.martin at gmail.com> wrote:
> Hi,
> 2011/8/22 Soeren Gebbert <soerengebbert at googlemail.com>:
>> The reason why i would like to create a branch is the experimental
>> character of the implementation.
>> The goal is not to break grass and its functionality, but as i am not
>> absolutely sure about the implementation, i can not assure this.
>> Using trunk i must be much more careful and disciplined .... making it
>> harder to be creative.
> in this case I could imagine special branch but only for a short-term
> period, in other words merge to trunk ASAP.
Soeren, would you be able to keep "your" branch in sync with the pace
of changes happening in trunk?
Markus
