[GRASS-dev] trunk r47474 breaks OGSF rendering of points on surface
Anna Kratochvílová kratochanna at gmail.com
Tue Aug 23 05:50:56 EDT 2011
2011/8/23 Martin Landa <landa.martin at gmail.com>:
> Hi,
> 2011/8/23 Maris Nartiss <maris.gis at gmail.com>:
>> In case You like to crash it too: start wxgui; as the first thing
>> switch from 2D to 3D; realize, that You forgot to add any data ->
>> switch back to 2D; add any raster; switch to 3D -> crash (and burn).
> it seems to be a bug ;-) Anyway you can add data also in 3D view mode...
> Martin
It's the same bug as before. With English locales it would work for
you I guess. It should be fixed now (r47845).
Anna
> Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
