[GRASS-dev] Re: [GRASS GIS] #1421: scalability of r.terraflow
GRASS GIS trac at osgeo.org
Tue Aug 23 20:24:13 EDT 2011
 Reporter:  dnewcomb                 |       Owner:  grass-dev@…
     Type:  enhancement              |      Status:  new
 Priority:  normal                   |   Milestone:  7.0.0
Component:  Default                  |     Version:  svn-develbranch6
 Keywords:  r.terraflow large grids  |    Platform:  Linux
      Cpu:  x86-64                   |
Comment(by dnewcomb):
 OK, I got it to work with the big grid.
 for types.h
 typedef short dimension_type; /* represent dimension of the grid */
 static const dimension_type dimension_type_max=SHORT_MAX;
 changed to :
 typedef long dimension_type; /* represent dimension of the grid */
 static const dimension_type dimension_type_max=LONG_MAX;
 for 3scan.h:
 line 127
         assert(ae == AMI_ERROR_END_OF_STREAM);
 changed to :
         assert((off_t)ae == AMI_ERROR_END_OF_STREAM);
 line 141
 changed to:
 output from command:
 GRASS 7.0.svn (ncstpft_nad83):/data2/grass7_svn/grass_trunk/bin.x86_64
 -unknown-linux-gnu > r.terraflow --overwrite elevation=nc_20ft_ncfpm
 filled=nc_fill direction=nc_direct swatershed=nc_sink
 accumulation=nc_flow_accum tci=nc_tci memory=8000
 stream_dir=/data2/bareearth stats=/data2/bareearth/stats2.out
 STREAM temporary files in /data2/bareearth  (THESE INTERMEDIATE STREAMS
 WILL NOT BE DELETED IN CASE OF ABNORMAL TERMINATION OF THE PROGRAM. TO
 SAVE SPACE PLEASE DELETE THESE FILES MANUALLY!)
 MFD flow direction
 D8CUT=999999986991104.000000
 Memory size: 7.81G (8388608000) bytes
 Memory manager registering memory in MM_IGNORE_MEMORY_EXCEEDED mode.
 total elements=6783000000, nodata elements=3291491362
 largest temporary files:
 FILL: 454.84G (488376000000) [-1806934592 elements, 72B each]
 FLOW: 312.17G (335184829248) [3491508638 elements, 96B each]
 Will need at least 909.67G (976752000000) space available in
 /data2/bareearth
 COMPUTING FLOW DIRECTIONS
 classifying nodata (inner & boundary)
 EMPQUEUEADAPTIVE: starting in-memory pqueue
 EMPQUEUEADAPTIVE: available memory: 7997.93MB
 EMPQUEUEADAPTIVE: desired memory: 7997.93MB
 sz_stream: 270400 buf_arity: 200 mm_overhead: 8666496 mm_avail:
 8386435434.
 EMPQUEUEADAPTIVE: memory overhead set to 8.26501MB
 EMPQUEUEADAPTIVE: pqsize set to 1047221117
 EMPQUEUEADAPTIVE: available memory: 7997.15MB
 EMPQUEUEADAPTIVE: desired memory: 7997.15MB
 8385624130.
 EMPQUEUEADAPTIVE: pqsize set to 1047119704
 assigning preliminary directions
 finding flat areas (plateaus and depressions)
 EMPQUEUEADAPTIVE: available memory: 7997.41MB
 EMPQUEUEADAPTIVE: desired memory: 7997.41MB
 8385894538.
 EMPQUEUEADAPTIVE: pqsize set to 1047153505
 EMPQUEUEADAPTIVE: available memory: 7996.64MB
 EMPQUEUEADAPTIVE: desired memory: 7996.64MB
 8385083234.
 EMPQUEUEADAPTIVE: pqsize set to 1047052092
 EMPQUEUEADAPTIVE: available memory: 7995.86MB
 EMPQUEUEADAPTIVE: desired memory: 7995.86MB
 8384271930.
 EMPQUEUEADAPTIVE: pqsize set to 1046950679
 assigning directions on plateaus
 generating watersheds and watershed graph
 EMPQUEUEADAPTIVE: available memory: 7998.96MB
 EMPQUEUEADAPTIVE: desired memory: 7998.96MB
 sz_stream: 270424 buf_arity: 200 mm_overhead: 8705664 mm_avail:
 8387517074.
 EMPQUEUEADAPTIVE: memory overhead set to 8.30237MB
 EMPQUEUEADAPTIVE: pqsize set to 261837856
 flooding depressions
 available memory: 7999MB (8387787594B)
 UnionFind::makeSet: reallocate double 2000
 UnionFind::makeSet: reallocate double 4000
 UnionFind::makeSet: reallocate double 8000
 UnionFind::makeSet: reallocate double 16000
 UnionFind::makeSet: reallocate double 32000
 UnionFind::makeSet: reallocate double 64000
 UnionFind::makeSet: reallocate double 128000
 UnionFind::makeSet: reallocate double 256000
 UnionFind::makeSet: reallocate double 512000
 UnionFind::makeSet: reallocate double 1024000
 UnionFind::makeSet: reallocate double 2048000
 UnionFind::makeSet: reallocate double 4096000
 UnionFind::makeSet: reallocate double 8192000
 UnionFind::makeSet: reallocate double 16384000
 UnionFind::makeSet: reallocate double 32768000
 warning: watershed 1 (R=1) not done
 warning: watershed 31667557 (R=31688834) not done
 warning: watershed 31667558 (R=31688834) not done
 warning: watershed 31674901 (R=31688834) not done
 warning: watershed 31676231 (R=31688834) not done
 warning: watershed 31688834 (R=31688834) not done
 REASSIGNING DIRECTIONS
 8385624138.
 EMPQUEUEADAPTIVE: pqsize set to 1047119705
 EMPQUEUEADAPTIVE: available memory: 7996.38MB
 EMPQUEUEADAPTIVE: desired memory: 7996.38MB
 8384812834.
 EMPQUEUEADAPTIVE: pqsize set to 1047018292
 EMPQUEUEADAPTIVE: available memory: 7995.61MB
 EMPQUEUEADAPTIVE: desired memory: 7995.61MB
 8384001530.
 EMPQUEUEADAPTIVE: pqsize set to 1046916879
 EMPQUEUEADAPTIVE: available memory: 7994.83MB
 EMPQUEUEADAPTIVE: desired memory: 7994.83MB
 8383190226.
 EMPQUEUEADAPTIVE: pqsize set to 1046815466
 creating flowStream: [AMI_STREAM /data2/bareearth/flowStream 0]
 compute flow directions done.
  100%
  100%
  100%
 COMPUTING FLOW ACCUMULATION
 creating sweep stream from fill output stream
   sorting sweep stream
 sweeping: EMPQUEUEADAPTIVE: starting in-memory pqueue
 EMPQUEUEADAPTIVE: available memory: 7999.73MB
 EMPQUEUEADAPTIVE: desired memory: 7999.73MB
 8388328213.
 EMPQUEUEADAPTIVE: pqsize set to 261863204
  100%
 sorting sweep output stream
  100%
 r.terraflow complete.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1421#comment:1>
