[GRASS-dev] color tables for vector
Martin Landa landa.martin at gmail.com
Wed Aug 24 07:01:03 EDT 2011
2011/8/22 Glynn Clements <glynn at gclements.plus.com>:
>> There is one open issue. How to write color tables for vector maps
>> which are not located in the current mapset. I was thinking about
>> 'vector/<name>/colr2`, but it would require quite lot changes in
>> gislib (at least in G__ls()) etc, the second option which came to my
>> mind is 'vector2/<name>/colr2' as destination file for color table.
>> What do you think?
> I'd suggest using the same mechanism as for rasters, but with a
> different top-level directory name, e.g. vcolr2/<mapset>/<name>.
done in r47867.
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
