[GRASS-dev] NVIZ problem with 3D polygons
Markus Neteler neteler at osgeo.org
Thu Aug 25 09:47:24 EDT 2011
On Thu, Aug 25, 2011 at 10:18 AM, del cadarn <del_cadarn at hotmail.com> wrote:
> Your solution worked for the v.extrude buildings... brilliant.
excellent!
> However it doesn't work for the imported DXF, here is a description of the
> details
>  |   Number of points:       0               Number of areas:      0          |
>  |   Number of lines:        0               Number of islands:    0          |
>  |   Number of boundaries:   0               Number of faces:      53516      |
>  |   Number of centroids:    0               Number of kernels:    0          |
>  |   Map is 3D:              Yes                                              |
>  |   Number of dblinks:      1
Please also report the top/bottom output (B and T).
> Do I need to apply v.type on another categorie?
In this case no since you have already faces.
Markus
