[GRASS-dev] NVIZ problem with 3D polygons
del cadarn del_cadarn at hotmail.com
Thu Aug 25 11:29:32 EDT 2011
Dear Mr. Neteler,
here are the full details...
 | Layer:           turbine                                                   |
 | Mapset:          user1                                                     |
 | Location:        nc_spm_08                                                 |
 | Database:        \mygrass                                                  |
 | Title:           turbine                                                   |
 | Map scale:       1:2400                                                    |
 | Map format:      native                                                    |
 | Name of creator: Del Jasmin-Bélisle                                        |
 | Organization:    GRASS Development Team                                    |
 | Source date:                                                               |
 |   Type of Map:  vector (level: 2)                                          |
 |   Number of points:       0               Number of areas:      0          |
 |   Number of lines:        0               Number of islands:    0          |
 |   Number of boundaries:   0               Number of faces:      53516      |
 |   Number of centroids:    0               Number of kernels:    0          |
 |   Map is 3D:              Yes                                              |
 |   Number of dblinks:      1                                                |
 |         Projection: Lambert Conformal Conic                                |
 |               N:        142.936628    S:       -142.936628                 |
 |               E:         20.646225    W:        -20.646225                 |
 |               B:       -192.046085    T:        192.046097                 |
 |   Digitization threshold: 0                                                |
 |   Comments:        |
Thank you for your help,
                        Delphine
> From: neteler at osgeo.org
> Date: Thu, 25 Aug 2011 15:47:24 +0200
> Subject: Re: [GRASS-dev] NVIZ problem with 3D polygons
> To: del_cadarn at hotmail.com
> CC: grass-dev at lists.osgeo.org
> On Thu, Aug 25, 2011 at 10:18 AM, del cadarn <del_cadarn at hotmail.com> wrote:
> > Your solution worked for the v.extrude buildings... brilliant.
> excellent!
> > However it doesn't work for the imported DXF, here is a description of the
> > details
> >  |   Map is 3D:              Yes                                              |
> Please also report the top/bottom output (B and T).
> > Do I need to apply v.type on another categorie?
> In this case no since you have already faces.
> Markus
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20110825/056c5fb7/attachment.html
