[GRASS-dev] Re: [GRASS GIS] #1428: WinGRASS 6.4.1 fails to start after installation
GRASS GIS trac at osgeo.org
Fri Aug 26 17:42:18 EDT 2011
 Reporter:  dhastings                                              |       Owner:  grass-dev@…
     Type:  defect                                                 |      Status:  new
 Priority:  blocker                                                |   Milestone:
Component:  Installation                                           |     Version:
 Keywords:  WinGRASS6.4.1 installation completes but does not run  |    Platform:  MSWindows 7
      Cpu:  x86-64                                                 |
Comment(by hamish):
 this is a FAQ, typically only seen on a rather new machine. The C runtime
 libraries you are missing come from Microsoft, you have to download them
 from them.
 do the files actually exist on you system? if so does the fix in #1354 fix
 things for you?
 if not you can download it from Microsoft's site (do a web search for it)
 or from
 http://www.dll-files.com/dllindex/dll-files.shtml?msvcp71
 see also  http://pcsupport.about.com/od/findbyerrormessage/a/msvcp71-dll-
 not-found-missing-error.htm
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1428#comment:1>
