[GRASS-dev] Re: [GRASS GIS] #1426: v.colors resetting vector display
GRASS GIS trac at osgeo.org
Sat Aug 27 11:31:44 EDT 2011
 Reporter:  cmbarton     |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  7.0.0
Component:  Default      |     Version:  svn-trunk
 Keywords:  v.colors     |    Platform:  Unspecified
      Cpu:  Unspecified  |
Comment(by cmbarton):
 This is fixed for the main display, though it would be nice if preview
 also looked like the main display too. The only issue is that now, a 'no
 color rules set' error is popping up when colorrules is launched and when
 a field is selected to create color rules, even if the color rules
 checkbox is not checked. Probably just needs a conditional for the error
 check in CreatColorTable or to move the error check to another position.
 Thanks much for the fix.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1426#comment:13>
