[GRASS-dev] Re: name of nviz_cmd module
Sat Aug 27 20:18:13 EDT 2011
Martin Landa wrote:
> 2011/8/21 Michael Barton <Michael.Barton at asu.edu>:
> > I'd go with d.nviz.image because the result of the command is an image, not a script.
> if no objections I will rename `nviz_cmd` to `d.nviz.image`.
d.* should only be used for modules which use the display subsystem
(monitors, GRASS_PNGFILE, etc), which doesn't apply to nviz_cmd.
