[GRASS-dev] where to store GRASS settings: GISRC and wx settings
Markus Metz markus.metz.giswork at googlemail.com
Mon Aug 29 16:05:23 EDT 2011
On Mon, Aug 29, 2011 at 9:57 PM, Martin Landa <landa.martin at gmail.com> wrote:
> Hi,
> 2011/8/29 Hamish <hamish_b at yahoo.com>:
>> re. ~/.grassrc6, do not mess with the location of longstanding
>> support files. 6.x is the **stable** branch which should have
>> its core firmly in bug-fix-only mode.
> 6.4 is stable branch, not 6.5. Anyway it will not brake anything, old
> location of rc/wx file is read, GRASS just stores new files on other
> position. Nothing is going to broken. It's better to make current mess
> smaller then to leave as it is.
I have applied the suggested changes to 7 and 6.5. 6.4 needs some
modification because the wxGUI is not in sync with the lib/init code.
I tend to adjust the 6.4 wxGUI to lib/init and not vice versa, i.e.
leaving GISRC where it is for 6.4 and using 6.5 as testing ground.
Markus M
