[GRASS-dev] Re: [GRASS GIS] #1158: Removing vector map in Windows fails with "Unable to delete vector map"
GRASS GIS trac at osgeo.org
Tue Aug 30 02:28:06 EDT 2011
 Reporter:  lponti                                                        |       Owner:  grass-dev@…
     Type:  defect                                                        |      Status:  new
 Priority:  blocker                                                       |   Milestone:  6.4.2
Component:  Vector                                                        |     Version:  6.4.0
 Keywords:  wingrass, g.mremove, wildcards, v.in.ogr, v.select, g.remove  |    Platform:  MSWindows 7
      Cpu:  Unspecified                                                   |
Comment(by mmetz):
 Replying to [comment:44 glynn]:
 > Replying to [comment:42 mmetz]:
 > > Do the small differences in lib/gis/spawn.c between trunk and 6.4
 really make sense?
 > No; that file should be sync'd from trunk to 6.x.
 Done in r47965 and r47968 for 6.5 and 6.4, respectively.
 db_shutdown_driver() fixed in r47966 and r47969 for 6.5 and 6.4,
 respectively.
 The call to Vect_delete() by g.remove, g.mremove, v.in.ogr or any other
 module allowed to overwrite an existing vector map works for me now in
 Windows. Please confirm.
 Markus M
Ticket URL: <https://trac.osgeo.org/grass/ticket/1158#comment:45>
