[GRASS-dev] Re: [GRASS GIS] #1430: Buffer overrun in vector/diglib dig__fread_port_L with big-endian negative values on LP64 systems
GRASS GIS trac at osgeo.org
Wed Aug 31 04:14:27 EDT 2011
 Reporter:  rroliver                         |       Owner:  grass-dev@…
     Type:  defect                           |      Status:  new
 Priority:  normal                           |   Milestone:
Component:  Vector                           |     Version:  svn-trunk
 Keywords:  diglib portable LP64 big-endian  |    Platform:  Unspecified
      Cpu:  All                              |
Comment(by mmetz):
 Replying to [ticket:1430 rroliver]:
 > The code in dig!__fread_port_L is broken for handling big endian
 negative numbers on systems where sizeof(long) != PORT_LONG.
 > Presently the code fails to negate the value and will write 4 bytes past
 the end of the buffer.
 > Problem exists for all grass versions through to trunk...
 The patch seems to make sense but there are more subtle bugs in
 lib/diglib/portable.c related to big endian systems. Can you test grass7
 (trunk)? I have applied your patch plus some more modifications in trunk
 in r47992. After testing, they can be backported to 6.5. and 6.4.2.
 Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/1430#comment:1>
