[GRASS-dev] Re: where to store GRASS settings: GISRC and wx settings
Massimo Di Stefano massimodisasha at gmail.com
Wed Aug 31 05:20:17 EDT 2011
that's an  other one ...
i'm using 6.5 for my daily job with really good satisfaction.
6.4 is out of date if compared with 6.5 and 7.0 is too much unstable beacouse of the gui (wx on osx is a pain)
--Massimo.
Il giorno 31/ago/2011, alle ore 11.08, Margherita Di Leo ha scritto:
> Hi Markus and All,
> ---------- Forwarded message ----------
> From: Markus Neteler <neteler at osgeo.org>
> To: Markus Metz <markus.metz.giswork at googlemail.com>
> Date: Wed, 31 Aug 2011 09:12:38 +0200
> Subject: Re: [GRASS-dev] where to store GRASS settings: GISRC and wx settings
> On Wed, Aug 31, 2011 at 9:02 AM, Markus Metz
> <markus.metz.giswork at googlemail.com> wrote:
> > Glynn Clements wrote:
> >> Personally, I'd just kill the 6.5 branch. If something is too major to
> >> go into 6.4.x, it should be reserved for 7.0.
> > +1
> I am also not quite sure about the need of the 6.5 branch?
> For me it is sufficient to have 6.4 as production system and 7 as
> experimental system.
> Honestly, who's *using* it as a user?
> Because: yes, it can (could?) be branch to be used for testing but
> I actually don't know anyone who really uses 6.5 for work.
> Please tell us if you use 6.5 for work to understand if this branch is
> really needed.
> I use 6.5 for work. As a user, I can say that it is actually the most usable IMHO, G7 is not stable enough and the 6.4 is not so up-to-date.
> My 2 c.
> Regards,
> Markus
> madi
> Eng. Margherita Di Leo
> Ph.D. Candidate
> Methods and Technologies for Environmental Monitoring
> Department of Environmental Engineering and Physics (DIFA)
> University of Basilicata
> Campus Macchia Romana
> 85100 - Potenza
> Italy
> Office: +39-0971205360
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20110831/353ec22d/attachment.html
