[GRASS-dev] Re: [GRASS GIS] #198: v.in.ascii: column scanning is borked
GRASS GIS trac at osgeo.org
Wed Aug 31 09:26:26 EDT 2011
  Reporter:  hamish    |       Owner:  grass-dev@…
      Type:  defect    |      Status:  closed
  Priority:  critical  |   Milestone:  6.4.2
 Component:  Vector    |     Version:  svn-develbranch6
Resolution:  invalid   |    Keywords:  v.in.ascii
  Platform:  All       |         Cpu:  All
Comment(by mmetz):
 Replying to [comment:11 hamish]:
 > Replying to [comment:10 mmetz]:
 > > Attached is the las2txt output for srs.laz.
 > > I am pretty sure this problem is caused by las2txt which does
 > > not check if a given attribute exists. If it does not exist,
 > > some weird value is written.
 > correct. columns 6 and 7 are not empty.
 [snip]
 > I think it is reasonable for G_getl2() to stop on null terminators, and
 there's nothing more to do here but file a bug with `las2txt`.
 I would rather call this a user error that I did because the proper way to
 do it would be to investigate the .la[s|z] file first with `lasinfo`,
 decide what attributes I want to import based on the attributes available
 and then set the --parse options accordingly. Or use v.in.lidar which does
 it all automatically;-)
 Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/198#comment:12>
