[GRASS-dev] tickets to solve for GRASS 6.4.2 release
Markus Neteler neteler at osgeo.org
Wed Aug 31 10:32:58 EDT 2011
On Wed, Aug 31, 2011 at 3:20 PM, Markus Metz
<markus.metz.giswork at googlemail.com> wrote:
> Hi all,
> the list of blocker and critical tickets for 6.4.2 is reassuringly short:
Here some more issues (GRASS 6.4 bugs and wishes from Geostat2011):
* WX-GUI table view: selection by attribute crashes when the datatype
of the column doesn't match the datatype of the query condition. This
happens when quotes are used with a numeric column type, or when no
quotes are used with a character type.
try r47334 (trunk), backported to devbr6 in r47335
--> to be tested and backported to 6.4
*. hard-coded file extensions in wxGUI raster import, breaks with
non-standard suffix + raster importer: .asc is not supported for
ArcINFO ASCII files when using directory bulk import
--> we would need a list of allowed extensions per format (see
gui/wxpython/gui_modules/gselect.py)
* raster importer: when changing format, the selected directory is
cleared but should remain
--> open
* graphical modeler: dynamically read in module list + path
--> the locally installed Addons are not shown in the list.
==> right, addons are also not shown in the search tree or the menu,
please report it on trac
Reported as: http://trac.osgeo.org/grass/ticket/1420
--> open
* v.digit, when creating a new map, bring immediately the att table
manager up for definition of new table
try r47337 (trunk), backported to devbr6 in r47338
* display of attrcol in windows wxGUI crashes (d.vect)
--> open
* wxGUI windows: manuals tab: bind arrow keys / pgup / pgdown to
scrolling for easier navigation
- ML: it's working for me, you just need to click on the manual for
the focus. Do you mean to set the focus automatically when the page is
entered?
- MM: this focus thing is a bit difficult, and dangerous to fiddle
around with because MS Windows has different focus  handling than
Linux/Mac --> preserve portability
--> open
Markus
