[GRASS-dev] GRASS 6: GISRC on Windows
Sat Dec 3 06:30:52 EST 2011
Hamish wrote:
> also fwiw, "run commands" from the era when ~/.files
> were `source`d at program startup is pretty
> meaningless in this context. if it were going to be
> renamed (ie in trunk :-) perhaps it is better to
> change it to something more understandable than a
> semi-obsolete two letter acronym? On UNIX there is
> enough entrenched tradition to perhaps justify it,
Except that the "grassrc" file isn't actually an "rc" file.
It may have been at one time (given the G_getenv() name, I suspect
that GRASS variables may once have been actual environment variables),
but that's ancient history now.
