[GRASS-dev] Re: [GRASS-windows] compiling WINGrass Python Scripts - ExpatError
Wed Dec 7 16:23:13 EST 2011
Johannes Radinger wrote:
> I tried to run the script now manually with --help
> from the command line. For simplicicity I only tried
> v.krige.py, a python script that already comes with
> the GRASS 6.5 SVN install.
v.krige.py isn't a normal Python script; it has its own GUI.
> I also tried to run my own script without the .py ending and with --help:
> pythontest_l --help
> Traceback (most recent call last):
>    File "C:\OSGeo4W\apps\grass\grass-6.5.svn\scripts\pythonte
> st_l.py", line 42, in <module>
>      import grass.script as grass
> ImportError: No module named grass.script
You need:
	set PYTHONPATH=%GISBASE%\etc\python;%PYTHONPATH%
7.0 does this automatically, but 6.x doesn't.
> What is the normal way to run a python script in windows, with or
> without the .py ending?
I don't know. GRASS 6.x, Windows, and Python isn't a particularly
well-tested combination.
