[GRASS-dev] GRASS extensions/addons mismatch
    Martin Landa
    landa.martin at gmail.com
    Wed Dec 14 10:36:15 EST 2011
2011/12/14 Hamish <hamish_b at yahoo.com>:
>> $HOME/.grass<major_version>/addons
>> and on Windows to
>> $AppData\GRASS<major_version>\addons
> (i.e. if you didn't already have GRASS_ADDON_PATH set to something
> custom and you let the defaults make the choice for you)
right, I am speaking about the normal situation, bearing in mind that
99% percent of GRASS users even don't know about GRASS_ADDON_PATH
variable ;-)
>> This layout doesn't allow to install extensions for more
>> installed versions of GRASS. In other words, addons for
>> GRASS 6.4.2 and GRASS 6.5 are installed on the same place
>> $HOME/.grass6/addons or
>> I would suggest to change `addons` to
>> `addons<full_version>`,
>> concretely GRASS 6.4.2 addons would be installed to
>> $HOME/.grass6/addons642 or
>> $AppData\GRASS<major_version>\addons642
>> and GRASS 6.5 to
>> $HOME/.grass6/addons65 or
>> $AppData\GRASS<major_version>\addons65
>> What do you think?
> the path name gets a bit long, but for compiled code it
> seems necessary and I have no better suggestion on how to
> improve that or work around it.
It should be done before 6.4.2, if no objections I will implemented it
like that.
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
