[GRASS-dev] [GRASS GIS] #1510: Querying external PostGIS-layer with multiple geometries crashes wxpython-GUI
GRASS GIS trac at osgeo.org
Thu Dec 15 11:40:53 EST 2011
GUI
 Reporter:  grasslandtom                   |       Owner:  grass-dev@…
     Type:  defect                         |      Status:  new
 Priority:  normal                         |   Milestone:
Component:  wxGUI                          |     Version:  6.4.2 RCs
 Keywords:  wxpython, PostGIS, v.external  |    Platform:  Unspecified
      Cpu:  Unspecified                    |
 steps to reproduce:
 _ import a PostGIS-layer with multiple geometries; something like
 v.external dsn='db=mydb' out=vector layer='v_eca_data(coords_gk_em38)'
 _ adding the vector-layer to the map in the GUI raises on the console:
 ERROR 1: FEHLER:  aktuelle Transaktion wurde abgebrochen, Befehle werden
 bis zum Ende der Transaktion ignoriert
 DBMI-OGR driver error:
 Cannot select:
 select * from v_eca_data(coords_gk_em38)
 GRASS_INFO_WARNING(10090,1): Unable to open select cursor: 'select * from
 GRASS_INFO_END(10090,1)
 GRASS_INFO_ERROR(10093,1): Unable to describe table
 <v_eca_data(coords_gk_em38)>
 GRASS_INFO_END(10093,1)
 _ Clicking on a feature of the layer with the query tool on the map
 crashes the GUI and raises the same error
 It seems to me that the problem is the wrong table name in the query
 which should be
Ticket URL: <http://trac.osgeo.org/grass/ticket/1510>
