[GRASS-dev] Re: [GRASS GIS] #1513: Location Wizard's misleading label for XY new location creation method
GRASS GIS trac at osgeo.org
Sat Dec 17 18:13:13 EST 2011
 Reporter:  alf                                     |       Owner:  grass-dev@…
     Type:  defect                                  |      Status:  new
 Priority:  normal                                  |   Milestone:  6.4.2
Component:  wxGUI                                   |     Version:  6.4.1
 Keywords:  location wizard, ellipsoids, planetary  |    Platform:  All
      Cpu:  All                                     |
Changes (by hamish):
  * keywords:  => location wizard, ellipsoids, planetary
  * cpu:  Unspecified => All
  * milestone:  => 6.4.2
Comment:
 "Create a generic Cartesian coordinate system (XY)" sounds ok to me.
 btw I've added your ellipse.table.solar.system in trunk, TODO is a radio
 button in the ellipsoid choosing page of the Wizard to alternately select
 [*] Earth based, [ ] Planetary bodies, and then parse the other list. Even
 if most people don't use that I think some portion of them will have fun
 exploring, especially with MOLA and Moon elevation data being available
 for use in generic tutorials.
 I notice than in ellipse.table.solar.system some entries are upper cased
 and some are lowercased, and at least on UNIX that makes all the upper
 case ones come first if I combine the two ellipse.tables together. -> All
 upper or all lowercase?
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1513#comment:1>
