[GRASS-dev] GRASS && OpenCV
Mohammed Rashad mohammedrashadkm at gmail.com
Mon Dec 19 01:45:07 EST 2011
On Mon, Dec 19, 2011 at 12:16 AM, Markus Metz <
markus.metz.giswork at googlemail.com> wrote:
> On Sun, Dec 18, 2011 at 6:13 PM, Mohammed Rashad
> <mohammedrashadkm at gmail.com> wrote:
> > On Sun, Dec 18, 2011 at 9:13 PM, Martin Landa <landa.martin at gmail.com>
> > wrote:
> >> 2011/12/18 Mohammed Rashad <mohammedrashadkm at gmail.com>:
> >> >> echo /usr/lib/grass64/lib >> /etc/ld.so.conf
> >> >> ldconfig
> >> > Hi Hamish
> >> > I tried that but no luck :(
> >> well, and are really GRASS libraries installed in `usr/lib/grass64` ?
> > yes martin. I also installed grass 6.4.2 from source checkout
> That was not Martin's question. Martin asked if the GRASS libraries
> are really installed in `usr/lib/grass64`. By default, after `make
> install`, libraries are installed in `$prefix/grass-6.4.2svn/lib`,
> prefix would be `usr/local`on default. Please check again the
> directory `$prefix/grass-6.4.2svn/lib`, optionally replacing $prefix
> with your choice of prefix.
I installed grass from source it is installed on /usr/local/.grass-6.4.2svn
i also installed from lucid repos it is installed on /usr/lib/grass64
so there are two installations. I also tried to link with each sepreately
and add one by one to /etc/ld.so.cinbf
and do ldconfig
but still error
As my title indicates there is one more question GRASS && OpenCV. Is there
any need for it. If yes please tell me.....
Regards,
    Rashad
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20111219/49031011/attachment.html
