[GRASS-dev] grass7 not compiling
Markus Metz markus.metz.giswork at googlemail.com
Mon Dec 19 10:52:29 EST 2011
2011/12/19 Anna Kratochvílová <kratochanna at gmail.com>:
> Hi,
> I can't compile grass7, r49838
> Anna
> Errors in:
> /usr/local/src/trunk/vector/v.rectify
Please try r49839
Markus M
> anna at dell-desktop:/usr/local/src/trunk/vector/v.rectify$ make
> gcc  -g -Wall -Werror-implicit-function-declaration -fno-common
> -Wextra -Wunused
> -I/usr/local/src/trunk/dist.i686-pc-linux-gnu/include
> -D_FILE_OFFSET_BITS=64  -DPACKAGE=\""grassmods"\"
> -I/usr/local/src/trunk/dist.i686-pc-linux-gnu/include -o
> OBJ.i686-pc-linux-gnu/main.o -c main.c
> In file included from
> /usr/local/src/trunk/dist.i686-pc-linux-gnu/include/grass/vect/digit.h:3,
>                 from
> /usr/local/src/trunk/dist.i686-pc-linux-gnu/include/grass/vector.h:4,
>                 from main.c:23:
> /usr/local/src/trunk/dist.i686-pc-linux-gnu/include/grass/vect/dig_structs.h:30:21:
> error: ogr_api.h: No such file or directory
>                 from
>                 from main.c:23:
> /usr/local/src/trunk/dist.i686-pc-linux-gnu/include/grass/vect/dig_structs.h:417:
> error: expected specifier-qualifier-list before ‘OGRSFDriverH’
> main.c: In function ‘main’:
> main.c:121: warning: format not a string literal and no format arguments
> main.c:123: warning: format not a string literal and no format arguments
> main.c:137: warning: format not a string literal and no format arguments
> main.c:182: warning: format not a string literal and no format arguments
> main.c:208: warning: format not a string literal and no format arguments
> main.c:246: warning: format not a string literal and no format arguments
> make: *** [OBJ.i686-pc-linux-gnu/main.o] Error 1
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
