[GRASS-dev] trunk GUI fails
Markus Metz markus.metz.giswork at googlemail.com
Fri Dec 23 05:40:49 EST 2011
in trunk r49877 the GUI fails with
  File "/home/metz/src/grass-7.0.svn/dist.x86_64-unknown-linux-gnu/etc/gui/wxpython/wxgui.py",
line 34, in <module>
    from lmgr.frame import GMFrame
  File "/home/metz/src/grass-7.0.svn/dist.x86_64-unknown-linux-gnu/etc/gui/wxpython/lmgr/frame.py",
line 43, in <module>
    from lmgr.layertree        import LayerTree, LMIcons
  File "/home/metz/src/grass-7.0.svn/dist.x86_64-unknown-linux-gnu/etc/gui/wxpython/lmgr/layertree.py",
line 35, in <module>
    from mapdisp.frame       import MapFrame
  File "/home/metz/src/grass-7.0.svn/dist.x86_64-unknown-linux-gnu/etc/gui/wxpython/mapdisp/frame.py",
line 38, in <module>
    from vdigit.toolbars    import VDigitToolbar
  File "/home/metz/src/grass-7.0.svn/dist.x86_64-unknown-linux-gnu/etc/gui/wxpython/vdigit/toolbars.py",
line 24, in <module>
    from iclass.digit       import IClassIVDigit
  File "/home/metz/src/grass-7.0.svn/dist.x86_64-unknown-linux-gnu/etc/gui/wxpython/iclass/digit.py",
line 22, in <module>
    from vdigit.wxdigit import IVDigit
  File "/home/metz/src/grass-7.0.svn/dist.x86_64-unknown-linux-gnu/etc/gui/wxpython/vdigit/wxdigit.py",
line 33, in <module>
    from vdigit.wxdisplay import DisplayDriver, GetLastError
  File "/home/metz/src/grass-7.0.svn/dist.x86_64-unknown-linux-gnu/etc/gui/wxpython/vdigit/wxdisplay.py",
line 70, in <module>
    errtype = CFUNCTYPE(UNCHECKED(c_int), String, c_int)
NameError: name 'CFUNCTYPE' is not defined
Markus M
