[GRASS-dev] Re: trunk GUI fails
Markus Metz markus.metz.giswork at googlemail.com
Fri Dec 23 06:37:21 EST 2011
My bad. I disabled the transform library in my local copy which caused
an import error which in turn was not captured. Re-enabling the
transform lib helped. BTW, I had to revert the GUI to r49809 to get a
meaningful error message. And the transform lib should probably be
removed altogether from trunk because the imagery lib does a better
job at transforming coordinates.
Markus M
On Fri, Dec 23, 2011 at 11:40 AM, Markus Metz
<markus.metz.giswork at googlemail.com> wrote:
> in trunk r49877 the GUI fails with
> Traceback (most recent call last):
>  File "/home/metz/src/grass-7.0.svn/dist.x86_64-unknown-linux-gnu/etc/gui/wxpython/wxgui.py",
> line 34, in <module>
>    from lmgr.frame import GMFrame
>  File "/home/metz/src/grass-7.0.svn/dist.x86_64-unknown-linux-gnu/etc/gui/wxpython/lmgr/frame.py",
> line 43, in <module>
>    from lmgr.layertree        import LayerTree, LMIcons
>  File "/home/metz/src/grass-7.0.svn/dist.x86_64-unknown-linux-gnu/etc/gui/wxpython/lmgr/layertree.py",
> line 35, in <module>
>    from mapdisp.frame       import MapFrame
>  File "/home/metz/src/grass-7.0.svn/dist.x86_64-unknown-linux-gnu/etc/gui/wxpython/mapdisp/frame.py",
> line 38, in <module>
>    from vdigit.toolbars    import VDigitToolbar
>  File "/home/metz/src/grass-7.0.svn/dist.x86_64-unknown-linux-gnu/etc/gui/wxpython/vdigit/toolbars.py",
> line 24, in <module>
>    from iclass.digit       import IClassIVDigit
>  File "/home/metz/src/grass-7.0.svn/dist.x86_64-unknown-linux-gnu/etc/gui/wxpython/iclass/digit.py",
> line 22, in <module>
>    from vdigit.wxdigit import IVDigit
>  File "/home/metz/src/grass-7.0.svn/dist.x86_64-unknown-linux-gnu/etc/gui/wxpython/vdigit/wxdigit.py",
> line 33, in <module>
>    from vdigit.wxdisplay import DisplayDriver, GetLastError
>  File "/home/metz/src/grass-7.0.svn/dist.x86_64-unknown-linux-gnu/etc/gui/wxpython/vdigit/wxdisplay.py",
> line 70, in <module>
>    errtype = CFUNCTYPE(UNCHECKED(c_int), String, c_int)
> NameError: name 'CFUNCTYPE' is not defined
> Markus M
