[GRASS-dev] Re: [GRASS GIS] #1271: osgeo4w patch update
GRASS GIS trac at osgeo.org
Sat Feb 12 18:35:42 EST 2011
 Reporter:  jef          |       Owner:  grass-dev@…
     Type:  enhancement  |      Status:  new
 Priority:  major        |   Milestone:  6.4.1
Component:  Default      |     Version:  svn-releasebranch64
 Keywords:               |    Platform:  MSWindows Vista
      Cpu:  Unspecified  |
Comment(by hellik):
 Hi Hamish
 Replying to [comment:4 hamish]:
 > mostly I'm insterested to know if there are bugfixes in there we should
 know about, >what is needed for a osgeo4w compile, what are cosmetic
 changes, and what in there is >local preference/
 > personal setup.
 I've tried to extract only these things that seems to be necessary to
 compile in osgeo4w.
 see also http://lists.osgeo.org/pipermail/grass-
 dev/2011-February/053420.html
 Hi Helmut,
 On Sat, 12. Feb 2011 at 00:22:51 +0100, Helmut Kudrnovsky wrote:
 > checking for location of zlib includes...
 > checking for zlib.h... yes
 > checking for location of zlib library...
 > checking for deflate in -lz... no
 > configure: error: *** Unable to locate zlib library."
 The MinGW cruft was removed from osgeo4w (maybe still not complete, but
 anyway).  I updated my package.sh accordingly (see ticket #1271).
 For starters the mingw-libs package with the library copies (foo.lib =>
 libfoo.a) are gone and package.sh now copies them before running
 configure.
 That's probably what hits you here.
 Jürgen
 some comments:
 - grass64svn_osgeo4w_gdal18_geos.patch: gdal-config and geos-config seem
 not be delivered anymore by osgeo4w, so therefore included in the grass-
 svn
 - there are compiling errors in lib/proj, therefore
 grass64svn_osgeo4w_libproj.patch
 - it seems that osgeo4w doesn't include projects.h, therefore
 grass64svn_osgeo4w_gregion.patch. but maybe this should be an osgeo4w-
 issue?
 best regards
 Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1271#comment:5>
