[GRASS-dev] Re: ctypes problem with Vect_open_old
Martin Landa landa.martin at gmail.com
Tue Jan 4 05:10:52 EST 2011
2011/1/4 Martin Landa <landa.martin at gmail.com>:
> The map is opened correctly, Vect_level() works. Anyway
> Vect_write_line() fails, seems to be that Map_info is corrupted. No
> clue at this moment.
when tracking pointer address of Map_info instance -
Vect_open_update() and Vect_level() points to the same address.
Pointer to Map differs in Vect_write_line(), no idea where the pointer
is being corrupted.
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
