[GRASS-dev] Re: [GRASS-SVN] r45036 - grass/branches/develbranch_6/vector/v.out.ogr
Martin Landa landa.martin at gmail.com
Fri Jan 14 16:49:48 EST 2011
2011/1/14  <svn_grass at osgeo.org>:
> Author: benducke
> Date: 2011-01-14 13:04:44 -0800 (Fri, 14 Jan 2011)
> New Revision: 45036
> Modified:
>   grass/branches/develbranch_6/vector/v.out.ogr/main.c
> Log:
> This commit contains some small bugfixes, code clean-ups and two new feature for v.out.ogr.
> 1. Fixed a but that would spawn ugly error messages in conjunction with the "-s" flag
> 2. Reduced the SQL SELECT statements to just one instead of one per feature, increasing output speed by several magnitudes.
> 3. Added a new "-z" flag, which provides a simple and robust means of producing 3D ESRI Shapefiles
> --> Please test intensively!
please, could you use trunk as development branch and optionally
backport the changes to devbr6? Devbr6 is intended to be a test-bed
for relbr64 backports! Go for GRASS 7!
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
