[GRASS-dev] Re: [GRASS GIS] #1266: d.vect has problems
GRASS GIS trac at osgeo.org
Wed Jan 26 03:09:17 EST 2011
  Reporter:  akbgf    |       Owner:  grass-dev@…
      Type:  defect   |      Status:  reopened
  Priority:  normal   |   Milestone:  7.0.0
 Component:  Display  |     Version:  svn-trunk
Resolution:           |    Keywords:  d.vect
  Platform:  Linux    |         Cpu:  x86-32
Changes (by akbgf):
  * status:  closed => reopened
  * resolution:  worksforme =>
Comment:
 Hi!
 I reopen the ticket, the problem is still there in r45179. [[BR]] Only
 vectors from the old saved workspace are visible and selections can be
 used. If I remove vector maps of the loaded workspace in the Layer Manager
 window and load a vector again then it is visible. After turning on a
 selection by category the vector disappears from the display window.
 Really, it is still there, I see info about vector elements by v.what,
 however the vector is non-visible. [[BR]] No error messages. [[BR]]
 The r45185 has the same problem, r44607 has no such problem.
 Andres Kuusk
Ticket URL: <http://trac.osgeo.org/grass/ticket/1266#comment:3>
