[GRASS-dev] GRASS-dev] 6.4.1 blocker bugs?
Martin Landa landa.martin at gmail.com
Sat Jan 29 07:13:00 EST 2011
2011/1/28 Helena Mitasova <hmitaso at unity.ncsu.edu>:
> Add scalebar - opens GUI with the button show/hide scale on and after clicking OK it stalls
> after opening "set options" clicking OK and then clicking OK in the show pannel it works -
> this looks like a GUI bug - should the OK buttong be greyed out as in d.legend to force user
> to open "set options" or it just should work with a single OK?
it works for me,
* add barscale
* click on OK
-> barscale is added to the map canvas.
Button OK can be enabled by default, because d.barscale can be lauched
without parameters. d.legend requires `map` paramater.
> Wish
> Import vector data default start with Directory button on with format ESRI shapefile
> there is a possible bug in File option (does not allow to select shp file).
File option works for me on Linux. I will test also on Windows.
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
