[GRASS-dev] Re: GRASS Test suite
Soeren Gebbert soerengebbert at googlemail.com
Mon Jul 4 04:52:10 EDT 2011
Hi all,
2011/7/4 Martin Landa <landa.martin at gmail.com>:
> Hi,
> 2011/7/4 Anne Ghisla <a.ghisla at gmail.com>:
>>> I'm just looking at grass7/raster/r.colors/ and the test files
>>> really dominate the module dir.
>> +1 from me on having a testsuite/ or tests/ subdir for each module.
> also +1 from me.
The directory layout has been discussed here:
http://osgeo-org.1803224.n2.nabble.com/Test-suite-for-GRASS-proposal-discussion-welcome-td6391218.html
I would suggest to either use reference_data/ subdir for each module,
so that the test scripts may stay in the module directory, not in a
subdirectory, or a testsuite/ subdir including all data?
I personally prefer a reference data subdir, to have a clear
separation of test case scripts and reference data. Otherwise the
reference data will dominate again and finding the test scripts is not
that obvious.
Best regards
Sören
> Martin
> Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
