[GRASS-dev] [GRASS GIS] #1403: r.fill.nulls seems to be failing in GRASS 7
GRASS GIS trac at osgeo.org
Thu Jul 14 22:07:54 EDT 2011
 Reporter:  cmbarton             |       Owner:  grass-dev@…
     Type:  defect               |      Status:  new
 Priority:  normal               |   Milestone:  7.0.0
Component:  Raster               |     Version:  svn-trunk
 Keywords:  nulls; r.fill.nulls  |    Platform:  Unspecified
      Cpu:  Unspecified          |
 I just tried to use r.fill.nulls to fill small holes in an SRTM. Even when
 I made the computational region very small, I get the same errors (listed
 below) and nothing is filled.
 (Thu Jul 14 19:05:02 2011)
 r.fillnulls input=SRTM_ffB03_p231r081 at dem
 output=SRTM_ffB03_p231r081_filled smooth=1
 Locating and isolating NULL areas...
 Reading raster map <r_fillnulls_45233>...
 Writing output raster maps...
 Color table for raster map <r_fillnulls_45233.buf> set to
 'r_fillnulls_45233'
 Creating interpolation points...
 Extracting points...
 Building topology for vector map <vecttmp_fillnulls_45233 at dem>...
 Registering primitives...
 3377 primitives registered
 3377 vertices registered
 Building areas...
 0 areas built
 0 isles built
 Attaching islands...
 Attaching centroids...
 Number of nodes: 0
 Number of primitives: 3377
 Number of points: 3377
 Number of lines: 0
 Number of boundaries: 0
 Number of centroids: 0
 Number of areas: 0
 Number of isles: 0
 r.to.vect complete.
 Interpolating 3377 points
 Note: The following warnings may be ignored.
 Removing raster <MASK>
 Using segmentation for interpolation...
 Reading features from vector map ...
 Reading nodes from vector map ...
 Strip exists with insufficient data
 Zero points in the given region
 ERROR: Input failed
 Note: Above warnings may be ignored.
 Patching fill data into NULL areas...
 ERROR: Raster map <r_fillnulls_45233_filled> not found
 Filled raster map is: SRTM_ffB03_p231r081_filled
 Unable to write history for <SRTM_ffB03_p231r081_filled>. Raster map
 <SRTM_ffB03_p231r081_filled> not found in current mapset.
 Done.
 Removing raster <r_fillnulls_45233>
 Removing raster <r_fillnulls_45233.buf>
 Removing raster <r_fillnulls_45233_filled>
 <r_fillnulls_45233_filled> nothing removed
 Removing vector <vecttmp_fillnulls_45233>
 Raster map <MASK> not found
 <MASK> nothing removed
 (Thu Jul 14 19:05:04 2011) Command finished (2 sec)
Ticket URL: <http://trac.osgeo.org/grass/ticket/1403>
