[GRASS-dev] [GRASS GIS] #1380: GRASS6.4.1 WX-Python GUI, menu does not work at all
GRASS GIS trac at osgeo.org
Thu Jun 2 01:08:49 EDT 2011
 Reporter:  naokiueda       |       Owner:  grass-dev@…
     Type:  defect          |      Status:  new
 Priority:  blocker         |   Milestone:  6.4.2
Component:  wxGUI           |     Version:  6.4.1 RCs
 Keywords:  WX Python Menu  |    Platform:  MSWindows 7
      Cpu:  Unspecified     |
 I downloaded latest GRASS6.4.1 and tested.
 I tested WX-Python GUI.
 Windows7, Japanese environment.
 Most Menu and commands does not work at all.
 TckTk GUI forks fine, though.
 There are error messages shown in command console.
 Unless this is solved, WX-Python GUI is useless.
 Note that, this may be same problem as OSGEO4W Track ticket#228 by
 Mr.Hayashi.
 Regards,
 Nao
 Error when I put [Add Raster Map] button.
   File "C:/Program Files/GRASS 6.4.1/etc/wxpython/wxgui.py",
 line 1180, in OnAddRaster
 self.curr_page.maptree.AddLayer('raster')
   File "c:/osgeo4w/usr/src/grass641_release/dist.i686-pc-
 mingw32/etc/wxpython/gui_modules/layertree.py", line 821, in
 AddLayer
 mingw32/etc/wxpython/gui_modules/layertree.py", line 882, in
 PropertiesDialog
 mingw32/etc/wxpython/gui_modules/menuform.py", line 2049, in
 ParseCommand
 mingw32/etc/wxpython/gui_modules/menuform.py", line 2020, in
 ParseInterface
   File
 "c:\OSGeo4W\apps\Python25\lib\xml\etree\ElementTree.py",
 line 963, in XML
 parser.feed(text)
   File
 line 1245, in feed
 self._parser.Parse(data, 0)
 xml.parsers.expat
 ExpatError
 unknown encoding: line 1, column 30
 Error when I put [Add 3D vector Map] button
 line 1307, in OnAddRaster3D
 self.curr_page.maptree.AddLayer('3d-raster')
 AddLayer
 mingw32/etc/wxpython/gui_modules/layertree.py", line 886, in
 PropertiesDialog
 ParseCommand
 ParseInterface
   File
 line 964, in XML
 return parser.close()
   File
 line 1254, in close
 self._parser.Parse("", 1) # end of data
 xml.parsers.expat
 ExpatError
 no element found: line 1, column 0
 Error when I enter "g.version" in command console
 parser.feed(text)
   File
 line 1245, in feed
 xml.parsers.expat
 ExpatError
Ticket URL: <http://trac.osgeo.org/grass/ticket/1380>
