[GRASS-dev] compiling errors - grass65svn compiled in the osgeo4w-stack
Martin Landa landa.martin at gmail.com
Thu Jun 2 17:50:12 EDT 2011
2011/6/2 Glynn Clements <glynn at gclements.plus.com>:
> is an order-only dependency, which requires GNU make 3.81. In 6.x,
> this syntax is normally conditional upon "ifneq ($(BROKEN_MAKE),)". It
> appears that someone back-ported from 7.0 (where GNU make 3.81 is a
> requirement) without changing this.
wouldn't be better to sync makefile systems in GRASS6 with GRASS7 and
require 3.81 also for GRASS6?
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
