[GRASS-dev] ] LiDAR LAS import - filter on import?
Doug_Newcomb at fws.gov Doug_Newcomb at fws.gov
Fri Jun 3 10:57:50 EDT 2011
>>Markus,
       >> Were you planning on adding filtering options by return number
on v.in.lidar?  It occurs to me that you could speed things up by only
processing the subset of the data that you want to >>use.   I could see it
being a useful thing to create a vector layer composed only of 1st returns
( top of canopy/buildings)  Selecting only last returns is useful, as well
as selecting points that >>are neither first nor last returns .
>Yes, I was thinking of such filter options, they would be very easy and
straightforward to implement, something like v.in.lidar
returns=[all,first,last,middle]. Currently there is only spatial
>filtering available.
Excellent!
>I was also thinking about an option to select columns to be imported as
attributes, equivalent to the las2txt --parse option, but could not yet
come up with a user-friendly solution: flags >don't work because too many
and conflicting with existing flags, a parse option very much like the one
of las2txt is too cryptic. I think I will settle for something like
v.in.lidar >attributes=coords,classes,color,egde,angle,return,nreturns,...
where the attributes option takes none, one or multiple answers
Sounds good.  That would have the advantage of "standardizing" the lidar
attibute names for future lidar point processing modules in GRASS
>Markus M
Doug
Doug Newcomb
USFWS
Raleigh, NC
919-856-4520 ext. 14 doug_newcomb at fws.gov
The opinions I express are my own and are not representative of the
official policy of the U.S.Fish and Wildlife Service or Dept. of the
Interior.   Life is too short for undocumented, proprietary data formats.
Markus Metz <markus.metz.giswork at googlemail.com>
06/03/2011 10:36 AM
To
cc
GRASS developers list <grass-dev at lists.osgeo.org>
Subject
Re: [GRASS-dev] ] LiDAR LAS import - filter on import?
On Fri, Jun 3, 2011 at 3:30 PM, <Doug_Newcomb at fws.gov> wrote:
Markus,
        Were you planning on adding filtering options by return number on
processing the subset of the data that you want to use.   I could see it
as selecting points that are neither first nor last returns .
returns=[all,first,last,middle]. Currently there is only spatial filtering
available.
come up with a user-friendly solution: flags don't work because too many
v.in.lidar attributes=coords,classes,color,egde,angle,return,nreturns,...
Markus M
        I've been primarily working with aggregate las files that I have
dumped to text ( via liblas las2txt )  and then parse via python for
first, middle, and last  returns. I have not taken the time to learn C
yet, but perhaps the logic of these simple python programs would be useful
The following is the python script I use to separate the last returns.
import struct,os,string,re,binascii,glob
infile = raw_input("Enter the aggregate lidar filename:  ")
outfil = raw_input("Enter the ASCII output filename for the Lidar Data:
intxt=open(infile,'r')
outtxt=open(outfil,'w')
while 1:
    lasline=intxt.readline()
    lasinfo=lasline.split(',')
    if (len(lasinfo))< 5:break
    numreturns=int(lasinfo[4])
    returnnum=int(lasinfo[5])
    # In the data input file for this instance, the number of returns
    # is the fifth column, and the return number is the sixth column (
x=1,y=2,z=3,intensity=4).
    # If the value of these colums is equal, it should be the last return.
    if ( numreturns==returnnum):
        outtxt.write(lasline)
intxt.close()
outtxt.close()
For parsing the first returns,  substitute if (returnnum==1):
Here is the python script I use to separate out the "middle" returns.
while 1:
    # If the value of these colums is equal, it should be the last return,
so skip that entry
    # If the return number is 1 , skip that value.  All other values are
middle canopy values,which is what we want.
    if ( numreturns==returnnum): continue
    if (returnnum==1):continue
intxt.close()
outtxt.close()
I really appreciate your adding lidar data classifications from the
standard into the program.  I haven't actually seen any lidar data with
classifications yet, but I have hope for the future :-).
As a bit of background , I'm taking the last returns and then running
r.in.xyz to create a raster with the intensities as the z values to get
relative soil moistures, and looking at points that are neither first nor
last returns as a possible measure of vegetation density.  It works great
for large datasets( > 4 billion points) , but I'm feeling the need for
more point analysis.
Doug
Doug Newcomb
USFWS
Raleigh, NC
Sent by: grass-dev-bounces at lists.osgeo.org
06/03/2011 02:20 AM
To
Hamish <hamish_b at yahoo.com>
cc
Subject
[GRASS-dev] Re: [GRASS-user] LiDAR LAS import
Hamish wrote:
> Markus Metz wrote:
[snip]
>> v.in.lidar is a notch faster than las2txt | v.in.ascii. And
>> easier to use...
> I'm not too surprised the speed difference is not so huge, as
> unix pipes are very efficient. but the easier to use thing is
> very important.. both las2txt and v.in.ascii are a bundle of
> command line switches to get right.
>> Speed comparisons:
>> # sample las file with 1,287,775 points
>> # with table and topology
>> real    6m34.430s
>> real    6m13.823s
>> # without table, with topology
>> real    1m53.578s
>> real    1m44.876s
> I take it that without topology it runs in just seconds?
Update: no attribute table, no topology
time las2txt -i points.las --stdout --parse xyz --delimiter "|" |
v.in.ascii in=- out=points_ascii -ztb x=1 y=2 z=3
real                 0m20.932s
user                 0m18.424s
sys                 0m6.869s
time v.in.lidar in=points.las out=points_las -obt
real                 0m9.117s
user                 0m2.946s
sys                 0m5.985s
Markus M
grass-dev mailing list
http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20110603/4382bac6/attachment-0001.html
