[GRASS-dev] First java module with native grass7 library access
andrea antonello andrea.antonello at gmail.com
Sun Jun 5 10:32:28 EDT 2011
Well done Soeren,
looking forward to have a look at it. Thanks for the compilation
guide, will be handy to have.
Ciao,
Andrea
On Sat, Jun 4, 2011 at 2:55 PM, Soeren Gebbert
<soerengebbert at googlemail.com> wrote:
> Dear Developers and Users,
> JFYI i am developing an object oriented wrapper library
> (vtk-grass-bridge) around the grass7 raster, vector, dbmi and raster3d
> libraries based on VTK[1], which supports now the implementation of
> Java based grass modules with native library access. Additionally C++
> and Python are supported using the VTK wrapping approach.
> I have implemented a simple module which samples multiple raster maps
> based on the points of an input vector map.It shows how the
> vtk-grass-bridge works with vector, raster and dbmi access. This
> module is implemented in C++, Python and finally Java.
> Here the links:
> The vtk-grass-bridge main page
> http://code.google.com/p/vtk-grass-bridge/
> The Java module v_sample_rast:
> http://code.google.com/p/vtk-grass-bridge/source/browse/trunk/Modules/Java/v_sample_rast.java
> The Python module v.sample.rast.py
> http://code.google.com/p/vtk-grass-bridge/source/browse/trunk/Modules/Python/v.sample.rast.py
> The C++ module v.sample.rast
> http://code.google.com/p/vtk-grass-bridge/source/browse/trunk/Modules/Cxx/v.sample.rast.cxx
> In case someone would like to try out the vtk-grass-bridge, here is a
> short introduction how to compile the vtk-grass-bridge:
> http://code.google.com/p/vtk-grass-bridge/wiki/HowToCompile
> Any feedback is very welcome.
> Best regards
> Soeren
> [1] http://www.vtk.org
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
