[GRASS-dev] Error compiling the latest grass7svn
Pierre Roudier pierre.roudier at gmail.com
Wed Jun 8 05:25:24 EDT 2011
Sorry, I did not include my ./configure line.
I do have the --with-gdal=[path/to/gdal-config]  option right. I did
not changed my configure options, I used the usual ones, which
compiled successfully on svn the last 6 months.
Pierre
2011/6/8 Moritz Lennert <mlennert at club.worldonline.be>:
> On 08/06/11 05:01, Pierre Roudier wrote:
>> Hi,
>> I just encountered the following error while compiling the last svn up
>> of grass_trunk:
>> In file
>> /usr/local/src/grass7-svn/grass_trunk/dist.x86_64-unknown-linux-gnu/include/grass/gprojects.h,
>> couldn't find ogr_srs_api.h
>> I turned ogr_srs_api.h to gdal/ogr_srs_api.h and it did pass the error
>> and compiled.
> using --with-gdal=[path/to/gdal-config] as a configure option should do the
> trick.
> Moritz
Scientist
Landcare Research, New Zealand
